I have to presume the tripod is not designed for climbing. I would look for a safe way to loosen bolts so I could lift the mast and antenna free from the tripod, then lay it over carefully to work on it.
An antenna alone is usually quite light, made of aluminum. A 10' mast section and antenna might weigh between 15 & 30 lbs. The challenge may come when the assembly is long and cumbersome to maneuver. This may be a two person job.
Please don't get hurt.
