Old 26-Jul-2010, 12:44 PM   #11
olimazi
VHF-Hi/UHF antenna
Thanks man, I am leaning towards the Winegard 7698P VHF-Hi/UHF antenna.
You're right I'm within 40-45 miles from my towers, but I'm a little worried about a big pine tree on my land next to my house in the direction I will be pointing the antenna.
Guess I will have to try and find out - I would hate to mount it and find out that the signal is blocked.
Is there anything I can do to test the signal before I put the antenna up?
Thanks for the help.
Originally Posted by kb2fzq View Post
With my phased pair of ANT-2075's, and an AntennaCraft 10G212 30db pre-amp, I pull stations 53 miles out to my south and 91 miles out to my north...the distances to your towers looks like they are under 50 miles out, personally, I would get a VHF-hi/UHF combo antenna, such as my ANT-2075 or similar yagi design...and as I mentioned, if you HAVE to get WPVI channel 6 , you're gonna have a BIG antenna, like mine....but, I believe, if you search, you might be able to get a VHF-lo/VHF-hi/UHF antenna that will get all your channels....I couldn't find one on the internet, but they used to make them, maybe not anymore....A combo VHF-hi/UHF would do the job for you....
olimazi is offline   Reply With Quote
