Old 27-Mar-2012, 6:08 AM   #57
Electron
Tv antennas and Tv reception
Install a Channel Master CM3412 or CM3414 distribution amplifier. A coax cable will go out to each from the distribution amplifier. If a CM3412 distribution is installed , the CM3412 has 2 outputs , one output will go to one Tv and the other output will go to the other Tv and the same logic applies to the CM3414. If three Tv's are connected to the CM3414 , then screw on a 75 ohm terminator on the unused output of the CM3414. http://www.channelmasterstore.com
