Old 26-Mar-2012, 3:41 PM   #3
signals unlimited
antennaman
This is easy. Most of your station are to your North, and strong enough to use a UHF antenna. In the attic would work however you will have twice the signal if you mount outside. I recomend a compact antenna, 10.5" X 12" X 4" built from fiberglass that would work very well and look great. You can paint it the color of your home.
www.tripleplayantenna.com
