Old 25-Mar-2012, 11:36 PM   #19
Electron
Tv antennas and Tv reception
Here are above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com , buy the ronard mounts at solidsignal by typing the word ronard in the solidsignal search box or by from ronard. Do not put the antenna in the trees to try and hide it , the trees Will reduce reception. Do not put the antenna down low on roof the reception Will be reduced , Do not hide the antenna behind the house the reception Will be reduced. Do not think up any tricky manuvers with the antenna , reception Will be reduced. Yes Do Mount the antenna away from the trees and other obstructions , antenna receive the best when the antenna has elbow room and nothing is crowding in to upset reception.
