Tv antennas and Tv reception
I do my best to provide information that is straight forward to the point and as close to the truth as possible. I do my best to not leave any room for misinformation and , wide eyed wild eyed speculation. When the HD7698P antenna is aimed at about 349 degree magnetic compass , Tv stations WKSY and WPXA are located on the side and at an angle on the side and back of the antenna. I am not saying that the stations will not be received , what I am saying is the stations might not be received , a lot depends on the local conditions , like , trees obstructing the reception in those directions or buildings obstructing those directions. As Always , when the Tv antenna is installed and aimed at the starting aim direction , the Tv antenna is then turned to the left and right to obtain the best reception , most digital Tv's have a signal strength meter that can be used to adjust the antenna.
