Old 25-Mar-2012, 1:06 AM   #3
First, I can't offer local knowledge for the Bay area.
You may want to use the Interactive TV Maps tool to generate a more precise TVFR.
That said, the first TVFR provided clearly says that you have little hope of reliable reception of KCRA. You have interference from KGO-real 35, KICU-real 36 and KFSF-real 34. Even if that was not the case, a noise margin of -13.9 and a 2-edge path make the situation very difficult.
A 10 element high-VHF antenna (or stacked set of two or four) may be able to see KSBW-real 8. You'd be gambling a bit.
Last edited by GroundUrMast; 25-Mar-2012 at 1:09 AM. Reason: Suggesting use of Interactive TV Maps
