Tv antennas and Tv reception
If it is the older discontinued DB4 that looks similer the U4000 then yes can use the older DB4 , remove the reflector screen. If is the newer DB4e then no , the newer DB4e is a highly 'tuned' antenna that works the best with the reflector and will not receive well at the back of the antenna with the reflector on the antenna.
