Old 24-Mar-2012, 7:48 PM   #2
Tv antennas and Tv reception
First: All Tv Antennas are HDTV Antennas , All Tv Antennas are Non HDTV Antennas , All Tv Antennas are Analog Tv Antennas , All Tv Antennas Receive what ever Tv Signal Is Transmitted. The antenna shown in the picture is a very old all channel antenna , looks in good condition , however is beyond it's useful service life. I recommend install a Winegard HD7698P antenna with a Antennas Direct CPA-19 preamp aimed at about 349 degree magnetic compass. Two Tv stations might not be received because the stations are weak and are being received on the side of the antenna , WPXA-DT channel 51 ION and WKSY-LD channel 22 Retro Tv Network. I recommend install the HD7698P antenna CPA-19 Preamp and see if WPXA and WKSY are received. Might require a second antenna. I recommend install the antenna and see what happens first. then report back here to this post. All the networks such as , NBC , ABC , CBS , PBS , CW , and more , will be received with the HD7698P/CPA-19. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. Here are some antenna mounts . http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html. Buy the ronard mounts at solidsignal by typing the word ronard in the solidsignal search box. Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.winearddirect.com , http://www.amazon.com. New RG-6 coax will be used out side.
