Old 23-Mar-2012, 6:30 PM   #2
The signal levels shown in your TV Fool report suggest you will need to mount the antenna system on the roof rather than in the attic.
I would suggest a UHF antenna such as the Antennas Direct DB4e aimed at about 155° (compass) and a high-VHF antenna such as the Winegard YA1713 or Antennacraft Y-10713 aimed at about 205° (compass).
Combining satellite signals and OTA signals into a common coax is done with a diplexer (Holland STVC for example). However, in your case I believe you'll need to use a preamp such as an Antennas Direct CPA-19 which like most preamps, is powered via the coax from a power supply in the building. The satellite system already places power on the coax to power and control the dish components. I think you'll be best served by keeping the satellite and OTA antenna systems separate.
