I vote for the 7000R, as Electron originally suggested. You have tons of signal, so you do not need much antenna gain. In addition, the 7000R is sensitive over a wide span of angles, so aiming does not have to be exact. Electron suggested 80 degrees so you can pick up the New Jersey PBS, Telemundo, and independent stations to the east-southeast.
