Old 22-Mar-2012, 5:44 PM   #1
DaveM
Best antenna in between clusters 180 degrees apart?
My TV Fool's report is
http://www.tvfool.com/?option=com_wr...0b8634f0973849
Currently using an RCA ANT 751 R inside without an amp or pre amp. The RCA ANT 751 R is not performing as well as I hoped. For example, reception of WFSB (Digital) Channel: 33 Network: CBS is very intermittent and only 11.7 miles away. I'm willing to buy or build (SBGH?) the best antenna or antennas to receive the most stations.
Planning for an attic install.
Which antenna(s) best suit(s) my location?
Do I need a pre amp?
Two antennas or one omnidirectional antenna?
I'm trying to avoid using a rotor or an a/b switch, but I will if that will work best.
Thank you for any help or suggestions
DaveM is offline   Reply With Quote
