Tv antennas and Tv reception
If subject is tv reception and grounding and wiring and etc. with a tv antenna and reception devices or FTA satellite reception or even internet streaming then it's open here. I do not get into telling people how to get pay cable services or the pay satellite services such as dish network or direct tv. If you choose to ground the antenna , the best location for grounding is the electric service ground at the building. There are different ways to connect the ground wire to electric service ground. Might be best to have a electrican show you the different ways to ground at electric service location on the building. Some examples of grounding would be the pay cable service ground or pay satellite ground. It is also best ground the coax with a coax grounding block at the same location. Home depot has all manner of grounding clamps and hardware. Use real 'copper ground wire' real copper ground wire is made for grounding , it is though and durable and it lasts a long time outside it's made that way.
