Tv antennas and Tv reception
WNPE , WNYF , WCFE , are strong transmissions at your location and yes will most likley be received through the back side of the antenna with the antenna aimed at the Canada tv stations. . As a test of the weak American stations the antenna will be aimed at , WWNY / WWTI at 219 degree magnetic compass - first and scan for CBS/Fox and ABC/CW. Then the antenna will be turned to WPTZ at 117 degree magnetic compass and rescan to see if NBC/This Tv is received. Depending on how the test goes with the weak American stations is the antenna set up I will recommend for the weak American stations. Most likley a second antenna a Winegard HD7698P with a CPA-19 preamp aimed at WWNY CBS/FOX , WWTI ABC/CW. Because WPTZ NBC will most likley not be received. So if you choose to do a second antenna in the future. That would be two separate antenna systems and the separate coaxes will go to the location of the tv and be connected to a remote control A/B antenna switch , Radio Shack #15-1968.
