Old 20-Mar-2012, 12:33 AM   #9
dumpingCable
Originally Posted by Dave Loudin View Post
Boo on the Terk antenna. The absolute last thing you need is an amplifier of any sort. We have recommended the RCA antenna to many people, and it is functionally the same as the HD7000R except for performance at ch. 6 (WPVI) - the 7000 is better. The CS2 is not designed for channel 6 reception.
However, since you've got tons of available signal the CS2 or the RCA should pick up ch. 6 anyway. So the question becomes spending somewhere around $30 for an antenna that is designed for your situation or three times that for "looks".
I much appreciate the suggestions...if i must go outside (and I will) I'm hoping to stay off the rooftop. My "Terk" was an attempt to see 'if' there was a more aesthetically viewable when mounted on my rear deck.
Thanks again, Ray
dumpingCable is offline   Reply With Quote
