Boo on the Terk antenna. The absolute last thing you need is an amplifier of any sort. We have recommended the RCA antenna to many people, and it is functionally the same as the HD7000R except for performance at ch. 6 (WPVI) - the 7000 is better. The CS2 is not designed for channel 6 reception.
However, since you've got tons of available signal the CS2 or the RCA should pick up ch. 6 anyway. So the question becomes spending somewhere around $30 for an antenna that is designed for your situation or three times that for "looks".
