Old 19-Mar-2012, 4:30 PM   #7
dumpingCable
If you end up mounting outside (which is better almost 100% of the time), 20' up with a clear view is great.
In addition to the HD7000R, Winegard's HD7015 and Antennacraft's C290 would be worth considering.
If I had a flat roof to work with, I'd consider a non-penetrating mount system: http://www.3starinc.com/non-penetrat...inch_o_d_.html
Thank you for the feedback and suggestions...'if' I go roof mount the three above certainly are cheap enough to purchase, and I can mount to my chimney stack.
However the three above wouldn't aesthetically look very nice mounted to the deck railing (neighbors and all)
Below is expensive but wouldn't be so much of an eye sore mounted to the deck. Feedback on this or something similar would be appreciated.http://www.bestbuy.com/site/Antennas...&skuId=9119642
Or...http://www.bestbuy.com/site/RCA+-+Ou...&skuId=9736728
Or...http://www.bestbuy.com/site/Terk+-+A...&skuId=9736682
Again, thank you for your time, Ray
BTW > this antenna would only be used for my living room 50" plasma.
My other two CRT TV's (upstairs bedrooms) are working GREAT with two little $10 RCA rabbit ears and loop.
dumpingCable is offline   Reply With Quote
