Old 18-Mar-2012, 5:55 AM   #3
Electron
Tv antennas and Tv reception
If the building is/has , concrete walls , concrete blocks , cinder blocks , bricks from ground to roof , big rocks for walls , metal framing construction , stucko WIRE , metal siding , metal roof , solar panels , metal backed insulation , then reception will be reduced and the U4000 antenna might need to be mounted above the roof.
