Old 18-Mar-2012, 5:46 AM   #2
Electron
Tv antennas and Tv reception
This recommendation is based on the Current Plus Pending Application Included UHF Digital Tv Stations/Channels tvfool radar report for 03-17-2012. The Canada Tv Stations Channels and USA , KVOS-DT 35 IND , KBCB-DT 19 IND. , K24IC-D 24 PBS , Stations Channels are very strong signal strength. If the building is wood with wood or vinyl siding then install a Antenna Craft U4000 antenna indoors or in the attic or above the roof. The metal reflector rods of the U4000 will be turned from the horizontal position by lifting the metal clips and turned to the vertical position , this will get the metal reflector rods out of the way so the , >< , shaped metal reception elements can receive at the front and back of the antenna. The U4000 will be aimed at about 315 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. Here are some places but not the only places to buy the U4000 antenna. http://www.saveandreplay.com , http://www.trentondistributors.com , http://antennacraft.net
