Old 16-Mar-2012, 3:24 AM   #10
Tv antennas and Tv reception
The television transmissions at your location are weak to Very Weak. The bigger the tv antenna is the more signal the tv antenna will collect. A amplifier can increase the strength of the signal that is collected by the antenna and push the signal on through the coax , but first the antenna has to collect the signal. Small antennas do not collect much signal , large antennas do. If you will like to do it a different way then install a Antennas Direct C5 VHF antenna and Antennas Direct DB4e UHF antenna the two antennas are connected together with a Antennas Direct UVSJ Uhf/Vhf separator joiner. A Antennas Direct CPA-19 preamp will amplify and push the tv signals through the coax out to the tv's. The CPA-19 preamp is connected to the output of the UVSJ. Mount the C5 below DB4e. The antenna height is 40 feet in the tvfool radar report , will the antennas be on a tower or a two story house?? Do you have mounting in place to mount the antennas on?? . http://www.antennasdirect.com , http://www.solidsignal.com , http://www.amazon.com
