Can you fit a large antenna such as the Antennas Direct 91XG, Winegard HD9095 or HD9032 in the attic space available while pointing at 229° compass?
Or, do you have a chimney to mount the modest profile Antennas Direct DB4e? (A considerably smaller cross section when considering the wind load issue)
If you are going to be splitting to several tuners, an Antennas Direct CPA-19 would easily overcome the cable and splitter losses.
