Old 14-Mar-2012, 6:35 PM   #4
Tv antennas and Tv reception
You said you would mount on the gable outside. For roof top antenna mounted above the roof outside such as a Winegard HD9095P antenna , Antennas Direct 91XG antenna or Antennas Direct DB4e antenna. A amplifier will not be needed. And you will receive all the channels down the list to at least WFXT-DT 31 Fox. With one of the above antennas installed in the attic , a Antennas Direct CPA-19 preamp will be used. Most attics have electric power , so install the preamp and preamp power supply in the attic. With one of the above antennas and preamp in the attic you will receive down the list to at least WFXT.
