Old 14-Mar-2012, 5:19 AM   #22
Electron
Tv antennas and Tv reception
The repeater transmitters around the area are transmitting. The PBS station to the north east will likley be received with a Winegard Hd7696P antenna with a Antennas Direct CPA-19 preamp pointed at about 48 degree magnetic compass. Some of the other digital tv stations/channels might be received by a reflection off of Saw Mill Ridge to the west. The Only Way to find out is point the antenna at different places below the ridge , along that ridge that runs north and south. It is a point and scan type of a situation , looking for a hot spot. Many years ago , before the other helpers here at tvfool were even born. The Only Way to receive tv was analog broadcast television. 95% of the USA had only one or two tv channels. It was common in mountain type places to see tv antennas mounted at all manner angles and directions to get that tv transmission. The satellite image looks like the below ridge , the face surface is very rocky between the trees , thats good , tv signals bounce off of rocks real nice. Can I say that you will receive tv transmissions this way , the only way to find out is to try. If you go to the >>Start MAPS<< part of tvfool and make the antenna height 1 foot high and move the pointer to different points below the ridge you will see that the signal strengths are at the single digits ( positive NM dB ) positive NM(dB) numbers are good , negative NM(dB) numbers are not. Why one foot antenna height?? The reason is you are measuring the strength of the signal that is landing on and bouncing off the rock surface.
