Old 22-Jul-2010, 1:11 AM   #2
mtownsend
If you would like to get most of the channels on your list down to about the red zone, then a Winegard HD7698P, a Winegard AP-8700 pre-amp, and an antenna rotator would do the trick.
You seem to be close enough to Indianapolis, Cincinnati, and Dayton to get channels from all three markets if you use an antenna rotator.
If you don't mind limiting yourself to just stations from one market, then you can simplify your setup by pointing your antenna in just one direction and leaving out the antenna rotator.
