Tv antennas and Tv reception
The tv stations/channels to the south west are weaker of signal strength. The HD7698P antenna has a lot of signal gain and will supply signal to two tv's down to at least WNDY-TV digital UHF channel 32 MyNetwork. The digital tv channels to the south west below WNDY are Very Weak. If you will like to go after the Current and Pending Applications Included digital tv stations/channels that are below the WNDY. Then install a Channel Master CM3412 distribution amplifier. However keep in mind that even a distribution amplifier will likely make the reception of digital tv stations/channels to the north east worse when the antenna is pointed to the north east.
