Old 22-Jul-2010, 1:02 AM   #2
mtownsend
It looks like you might have decent access to some Columbus and Montgomery stations, but before we get into specifics, you should try to get a more precise analysis of your location. The report you have now is showing that the address was only resolved to "street level", so it might not be a completely accurate representation of the signals at your house.
What you can do is go to the Interactive Maps tool (here). After you enter your address, you will be presented with a map. If the pointer is at the wrong location, then you can drag-n-drop the pointer until it is right on top of your house. You can also edit the antenna height field to experiment with antenna heights.
When you are satisfied with the location and antenna height being analyzed, you can press the "Make Radar Plot" button to turn this into a report that you can post back here.
If your report still shows several stations in the green, yellow, or red zones, then you can probably pick them up with an appropriately configured antenna setup.
