Old 13-Mar-2012, 2:26 AM   #7
Grounding does not need to be a big ordeal.
Ideally, connect the mast to the electrical service ground using a #10 copper wire. Route the coax down-lead so that a coax grounding block can connect to the electrical service ground via a short length of #10 copper wire.
http://forum.tvfool.com/showthread.php?t=901
