Old 13-Mar-2012, 1:52 AM   #1
[derek]
Help with OTA - Middletown, CT
Howdy folks,
So I recently cut the satellite bill and dropped DirecTV and switched over to antennas.
A friend of mine gave me his old VHF and UHF (Yagi I believe) antennas. I do not have model numbers on the antennas.
I currently have them mounted on my roof and they sit about 25-30 feet off the ground.
I have the UHF running into a ChannelMaster preamp, and that is connected, along with the VHF, into a ChannelMaster preamp. I believe the model is a 7777.
I am currently receiving WTNH, WTIC and the local NBC affiliate.
My question is, would a ClearStream4 be a better bet for UHF? Is there a great all around VHF antenna I should purchase to replace the existing VHF antenna. Another question would be, should I run two UHF antennas pointing in different directions? I assume I would need another preamp as well for this would work.
Also, would it make more sense to try and pickup Massachusetts stations rather then some of the Hartford stations?
Here is my tvfool link: http://www.tvfool.com/?option=com_wr...0b86ae7a34ac3c
Any suggestions would be great (it's currently WW3 in the house over the loss of Satellite).
Thanks!
- Derek
[derek] is offline   Reply With Quote
