Old 12-Mar-2012, 8:57 PM   #5
ctevans1
Thanks again for your help. The antenna is installed and working great. ABC and one other channel come in clear, but have a slightly weak signal, so I may try moving the antenna to 315 degrees to see if it gets stronger.
I do have one more question. I didn't see anywhere in the instructions about grounding the antenna. I live in an area where lightning is pretty much non existent, but we do have the occasional storm that brings some. How important is it for me to ground the antenna, and what should I ground it to?
ctevans1 is offline   Reply With Quote
