Old 12-Mar-2012, 8:25 PM   #5
nitram
Originally Posted by Dave Loudin View Post
The antenna should be just fine, and it is almost equally sensitive over a very wide range of angles. Just aiming to the southwest as a start should work.
The splitter you linked to is a 4- way. Are you using all of them? If not, then either get a splitter with the right number of ports or get terminators for the ports you are not using. With the strength of your signals, you just might be getting multipath from signals coming in the open ports.
Thanks for the reply, I finally found time to play around with this thing again. Dave, you were right on the 4-way splitter. I bought and hooked up a 2-way and saw around a 5% signal boost, but I still cannot pick up PBS. I still don't understand why my signal is better inside the house than outside?
Originally Posted by Electron View Post
The broadcast digital tv tuners in the Tivos are trouble prone. So that you are not tempted to connect the Tivo during the test , I recommend disconnect the Tivo Completely and put the Tivo in a room where there is no Tv.
Electron, I also attempted to remove the splitter and Tivo from the setup, but honestly saw no further improvements compared to what I was seeing earlier.
nitram is offline   Reply With Quote
