The Channel Master CM-3016 comes to mind also. Antennacraft and Channel Master are known to be fairly easy to refold if you try the attic but need to move the installation outside. As @DL is saying... you have plenty of signal to work with... keep it simple.
I would avoid trying a 7-51 or 7-69 antenna. If you want to see WOI reliably (I would), use an antenna designed for the job.
Bottom line: The HD7000R, C290, CM-3016 and similar antennas are all worthy contenders.
