The antenna should be just fine, and it is almost equally sensitive over a very wide range of angles. Just aiming to the southwest as a start should work.
The splitter you linked to is a 4- way. Are you using all of them? If not, then either get a splitter with the right number of ports or get terminators for the ports you are not using. With the strength of your signals, you just might be getting multipath from signals coming in the open ports.
