Old 21-Jul-2010, 9:02 PM   #3
chumster
Originally Posted by Billiam View Post
How did you install the antenna? On the roof? Are nearby structures blocking the signal? What kind of cable are you using? What kind of pre amp?
Hi,
It is installed on the side of the house 20 feet above the ground and 5ft above the roof. There are no near structures. I am using the standard round cable wire I bought from a dealer. The pre-amp is a channel master the power supply says 0747. Channel 10 comes in crystal clear but nothing from the towers right near 10.
chumster is offline   Reply With Quote
