I would expect a Winegard HD7694P (or any of it's larger variants up to the 7698 ) would provide the directivity needed to overcome the suspected multipath as well as the moderate to low signal levels.
You may not need amplification, try with you existing splitter. If it has a fourth port, and you prove the need for an amplifier, use a CM-3410. If you need amplification and a 4-way splitter, use the CM-3414.
