Old 8-Mar-2012, 4:05 PM   #6
Re. Question #6) The neighbors trees stand out as the primary concern. If you can't get around or over them, a larger, more directional antenna may be needed for reliable reception. In some cases, the best you can do is go low to avoid the foliage.
If aiming toward Detroit involves the large trees, I'll express serious doubts about using an omnidirectional such as the CM3000 and advocate for a Winegard HD7694P.
