Old 8-Mar-2012, 7:30 AM   #11
Originally Posted by M rust View Post
Electron, Thanks for the reply. I will check out the winegard HD7698P antenna. Will the Radio Shack amplifier I have work, or should I spring for the new one? The amplifier's specs are:
Frequency: 54-806MHz
FM trap: >20dB @100MHz
Gain: 15dB at outdoor amplifier, up to 10dB at indoor amplifier (adjustable)
Thanks again for the help. I admit that I know nothing about antennas, so help from an expert is greatly appreciated.
MR
Originally Posted by MisterMe View Post
Although you did not specify your model Radio Shack amplifier, Electron is conversant with Radio Shack's product line. He did not recommend it. He recommended the CPA-19 because it is less likely to saturate when strong signals are present.
I agree with the recommendation of the CPA-19, it's a superior amplifier. But if the RS amplifier is already in-hand, try it.
