Old 8-Mar-2012, 6:56 AM   #10
MisterMe
Originally Posted by M rust View Post
Electron, Thanks for the reply. I will check out the winegard HD7698P antenna. Will the Radio Shack amplifier I have work, or should I spring for the new one? ...
Although you did not specify your model Radio Shack amplifier, Electron is conversant with Radio Shack's product line. He did not recommend it. He recommended the CPA-19 because it is less likely to saturate when strong signals are present.
MisterMe is offline   Reply With Quote
