Old 8-Mar-2012, 6:56 AM   #3
Electron
Tv antennas and Tv reception
Most of the Current and Pending Applications Included Digital Tv Stations are very weak signal strength so big antenna is needed for reliable reception. Reverse engineering your location to a few houses in an area , Your location is a location where installing the antenna 10 to 25 feet high is the best. Installing the antenna above 25 feet up to 60 feet improves reception very little. So install a Winegard HD7084P antenna with a Winegard AP8700 preamp above the roof aimed at about 0 degrees magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html
