Old 8-Mar-2012, 12:49 AM   #8
Tv antennas and Tv reception
A simple common 2 or 3 way splitter should work Ok with the CM2016 for reception of the digital tv stations down to KQDK-CA UHF channel 39 http://www.vasallovision.tv. . If the HD7696P antenna is installed , KPXC-DT UHF channel 21 ION is weak signal strength , If KPXC is not received when using a 2 or 3 way splitter and the HD7696P antenna then install a Channel Master CM3414 distribution amplifier in place of the 2 or 3 way splitter. Use 75 ohm screw on terminators on any unused output ports of the CM3414.
