Old 21-Jul-2010, 6:25 PM   #4
olimazi
Thanks for the heads up on the TVFool report link.
Static, I will research your recommendation.
My original plan was for an 8200U, but then I took into account size (the 7698P seems so much more compact).
I take it to receive the low VHF channels you need the bigger elements on the antenna.
I may forego trying for Ch. 6 from Philly if I can get Ch. 7 from NYC, this way I can put a smaller Ch. 7-69 antenna on the roof
Also, can you recommend a good rotator for my setup?
Thanks,
Originally Posted by No static at all View Post
Here is the link http://www.tvfool.com/?option=com_wr...cd7207a9e594f4
If I were in your shoes, I would use a Winegard 8200 antenna & Winegard 8700 preamp. The HDP-269 would probably be fine for 1-2 TV's, but I would think the 8700 would provide enough resistance to overload & provide additional gain for the weaker UHF's from NYC..
I would be afraid that the 7697 or 7698 antenna wouldn't get channel 6 well at that distance.
olimazi is offline   Reply With Quote
