Old 7-Mar-2012, 4:49 AM   #5
MisterMe
Originally Posted by ssscott View Post
Thanks for the Recommendation. I guess I was assuming I would need a bigger antenna. Another site recommended Winegard FV-HD30 Antenna. I would prefer it to go in the attic. Should I get a larger antenna if I decide to put it in the attic.
SSS
You should not go shopping for recommendations without independent knowledge to resolve conflicts among the recommendations. Your TV Fool Radar plot clearly shows that you need a VHF/UHF antenna. GroundUrMast recommended an excellent VHF/UHF antenna in the Winegard HD7694P. The Winegard FV-HD30 recommended by "another site" is nominally a compact VHF/UHF antenna. As an outdoor antenna for strong close-in stations, it is a decent antenna from a reputable company. For an attic mount, however, you cannot expect much better results than you would get by moving your indoor antenna to your attic.
