Old 7-Mar-2012, 4:44 AM   #4
Attic construction will attenuate the signal. So yes, if you can fit a larger antenna in the attic, some of that attenuation may be overcome.
Be fore you commit to a purchase, be sure there will be room to mount the antenna so no metal is near enough to interfere. Also be sure that the roof construction contains no metal or metal foil, either of which will block almost all of the signals.
