Old 7-Mar-2012, 1:32 AM   #1
BPuce
BPuce - Antenna Selection?
Hi... I just dumped cable and now looking for antenna advice.... Wondering what my best antenna / rotor option is. I also thought about using multiple antennas pointed in different directions but upon doing some reading this seems trouble prone...I have 3 relatively new TV's to feed a signal to.. Used to have a gable end mounted CM Quantum w/pre-amp & rotor years ago until the weather got to it. Would consider new gable mounting a new set-up or perhaps even do a tower if it is worth it? My old antenna was mounted about 25 ft high so i have included info for my location assuming 25 ft height here:
http://www.tvfool.com/?option=com_wr...0b86ab2fa66e62
(Also attached the info as well)
Any advice would be much appreciated... thanks... Bernie.
BPuce is offline   Reply With Quote
