You're situation will improve if you can mount higher. Can you consider between 35' & 50'? The DB-8 should be enough to give you access to KING, KOMO and KIRO.
However, the UHF only design of the DB-8 would not make it my first choice in the Puget Sound area. Starting from scratch, I would consider a Winegard HD7698P... with a good UHF antenna already in hand, an Antennacraft Y10713 or Winegard YA1713 would add several other stations. (Real channels 9, 11 & 13)
What amplifier are you using?
