Thread: OTA with DVR
Old 6-Mar-2012, 5:05 PM   #2
MisterMe
Originally Posted by Underdog View Post
So, I'm assuming I can use the tuner in this TV to get her ABC program and record with the DVR hooked to these outputs? The Sony Grand Wega we have appears to have a OTA tuner but no outputs only in. That is why I figured to use the older set for recording. I've seen mention of special tuner DVR combinations which confused me somewhat.
Thanks
You know what they say when you "assume"? The USA dropped full-power analog broadcasts back in 2009. Without an external ATSC tuner/converter, your Sony Grand WEGA is just a large and very heavy paperweight.
Your GF likes her stories? ChannelMaster's new CM7400, rebranded as the ChannelMaster TV, is what you need. It is a dual-tuner ATSC-compatible DVR and much more. It will allow you to record one HD station while watching another--or record both simultaneously.
MisterMe is offline   Reply With Quote
