Tv antennas and Tv reception
The signals traveling through 50 feet of coax has reduced the signal strength of the multipath enough so the tuner can deal with the reflected signals strength. Having the antenna in a window has reduced the signal reflections that would be picked up in the rooms of the apartment because the antenna is not in the rooms of the apartment , it is in the window. The 1296f variable attenuator will also reduce Strong main signal and the reflected (multipath) signals.
