Old 6-Mar-2012, 4:36 AM   #1
M rust
Port Ludlow antenna
Just bought a DB8 antenna with an amplifier to try for Seattle area stations about 25 miles away. The antenna is temporarily mounted about 10 feet off the ground and pointing SE which is approximately the right direction. There are hills between me and the transmitter, about 500feet high. I am unable to pick up any of the channels I would like ( abc, NBC, CBS ). Any suggestions? Should the antenna be higher? Also, would it help if the antenna was tilted up so it "looks up"?
TV Fool report link. Http://www.tvfool.com/?option=com_wr...0b869ca34eb7b0
Thanks, MR
M rust is offline   Reply With Quote
