Old 5-Mar-2012, 6:55 PM   #3
An attic mounted solution would not be my first choice. Though some signals make it through the roof, you're doing well to get the reception you're reporting.
Reception of WAGA, real channel 27 (virtual channel 5.n) calls for a tower or the largest antenna available... perhaps a combination of both.
Can you consider a tower? If so please post a TVFool report for 35' and 60' (or higher if you can consider such an option).
If not, a Winegard HD7698P or the combination of an Antennas Direct 91XG and Antennacraft Y10713 would be in order. Regardless of which antenna or combination you use, you'll have a better results by mounting outdoors in the clear.
