Unless you have extraordinary paths to DC, Harrisonburg, or Hagerstown, you will have to settle for the translators listed at the top of your report. These stations rebroadcast distant stations that would otherwise not be watchable. Electron listed the networks you will get. If you want all the details, go to rabbitears.info, click on the listings tab, then search for one of the translator call signs. You will see that you will get stations from different markets, such as Johnstown, PA, Morgantown, WV, and DC. A simple UHF antenna like an Antennas Direct DB2e would suffice.
