Old 4-Mar-2012, 10:57 PM   #26
LOTL
Originally Posted by Electron View Post
Yes you can use a CPA-19 preamp to provide a stronger signal to the Tv/s. For your reception situation with the antenna inside the house. The antenna is right there so put the CPA-19 preamp and the power supply for the preamp right there close to the antenna.
So if bringing my TV upstairs doesnt increase my signal strength, then the issue isnt the RG59 cable and you would recommend the CPA-19?
I guess the only other thing worth trying is moving the DB4e outside and up higher correct?
I think for the cost of the CPA-19, it might be the way to go vs the cost of moving the DB4e outside.
LOTL is offline   Reply With Quote
